Call Dataq Instruments at 330-668-1444330-668-1444 Email Dataq Instruments at sales@dataq.comsales@dataq.com View Dataq Instruments Shopping CartCart Login to your Dataq Instruments Ecommerce Store AccountAccount Search the Dataq Instruments Data Acquisition and Data Logger Web SiteSearch
Data Acquisition Categories
Starter Kits
Voltage
4-20 mA
USB
Ethernet
Temperature and Humidity
Thermocouple
RTD
Strain-based Sensor
Event, Count, State
Frequency, Rate, Count
Data Acquisition FAQ
Applications
Data Acquisition Software
Ready-to-run WinDaq
Data Acquisition to Excel
Program
.NET Class
ActiveX Control
Amplifiers
DI-8B Amplifiers
DI-5B Amplifiers
Three Easy Steps for Stand-alone Data Logging Using a DI-71x Data Logger
Configure
Connect a Data Logger to the USB or Ethernet port of your PC and run the provided set up software. Configure the data logger for your specific requirements in the following ways:
View the Demo
Record
Connect the signals you need to record, connect to any 9-36 VDC power source (or use the supplied power adaptor), and insert an SD memory card. Optionally connect the data logger's USB or Ethernet interface to a PC or LAN respectively to facilitate local or remote data uploading.
Press and hold the control button until the green Mode LED turns off, then release. The Mode LED changes to flashing red indicating that the data logger is recording data.
Upload Data and Analyze
Minutes, hours, or days later you can move captured data to your PC for detailed analysis. Upload data from SD memory locally over the USB port, remotely over the Ethernet port, or simply remove the SD memory from the data logger, slide it into any SD memory card reader, and instantly transfer its contents to your PC.
Recorded files are stored in a format that is compatible with our WinDaq Waveform Browser software and included with your Data Logger purchase, or can be downloaded by any of your colleagues so anyone, anywhere in the world can have access to your recorded data. Use our WinDaq Browser software to:
View the Demo
Stand-alone data logger applications have never been easier or more productive than with the DATAQ Instruments' Data Loggers and associated software.
